Bmxr152
- 579
- 2
- May 27, 2006
Gardnerville,
Nevada
Okay so i was doing my front control arms and sway bar links today and noticed when i spun the front tires in gear (with the rears on the ground) they did not lock up like normal. So i go under the the car and spin the front tires and dont see any movement on the driveshaft. This can explain why my car felt so loose in the snow recently.
I have a welded center diff and VCE on my jacks stage 2.1 transmssion. So im guessing the only thing that it could be is a stripped output shaft to the transfer case or stripped splines on the input to the transfer case. I was wondering how possible that could be. I have not done any launches with this transmission yet and i know when a month or so ago it worked fine. I didnt ever hear any weird noises or anything like that. I did however do some snow drifting and maybie that was to much stress on the splines. If anyone has any input or suggestions that would be great. Im going to look at it this weekend and see whats up.
