miguelmcv
Supporting Member
- 2,718
- 261
- May 3, 2009
Fresno,
California
I finally found a gsx.
The car was not working when I bought it, But after replacing the fuel pump and filter, Boom, It start wright up.
After driving it found out that, Transmission is bad, it make a bad noise, It sounds like a bad throw out bearing and 4th gear pops out, radiator is leaking and is from another car, They just fit it in there, The car was really bad, loose bolt all around the engine, leaks all over the place, dirty carpet, bad seats, etc, etc, etc.
I fixed every single thing, I am using it now and it drives well with out using the 4th gear, obviously I'm not forcing it at all.
The top paint of the car is really bad from the front all the way to the back (Hood, Roof, Trunk), and have some bends on the roof.
After waiting to find a good deal to get a gsx and sell my gst., now that I have it, I being looking at it and is bad, bad, bad decision, Because the car looks like is not being well care, and seriously, changing all the good stuff that I have in my gst to the gsx like MR2 Electric power steering system, seats, wideband, boost, oil gauges, engine, fuel system, etc, etc, etc,.... So I got to the conclusion on doing the GSX conversion.
I will convert my gst to gsx and the gsx to gst, so I can sell the gsx as a gst and get some money back.
I being reading and it doesn't looks to hard to do it, It seems the hardest part is to be swapping the rear Bolts for the rear end, so I start stripping down the car and open the holes to clear the bolts.
On my case, It will be more harder to do it, because not only will be a gsx conversion, but it will be a gst conversion as well, I have to take everything from the gst and put it on the gsx, so I have to do an extra hole to bring the 2 front bolts out of the gst (sub-frame) and open another ones on the gsx to install the bolts, this is because the gst has only one bolt that aligns with the gsx (rear bolts), the other front bolts of the gst are on a different location of the gsx. All the conversions that I have seeing, they leave the front bolt on the gst and just install the front bolts of the gsx, But because I need the gst bolt to put it on to the gsx I have to take them out.
The gst has 8inch in between the front and rear bolt (Sub-Frame), which the gsx has around 12 or 14inch, I don't remember but is some where around, I will take measurements tomorrow and verify, I will put some pics as well to let you guys see how is the project going and understand better on what I am trying to say.
