Boosted DSM 32
- 681
- 3
- Aug 21, 2011
McDonald,
Ohio
I almost have everything I need to get my motor back in the car for spring I'm super excited for this season! I just had a few small questions about some 16g times..
When the motor is back in the car ill have stock 6 bolt rebuilt block and stock 6 bolt head for now since I don't have enough for cams as springs for a little bit.. The supporting mods ill have is ported and polished mhi evo III 16, Dsmlink v3 with speed density, pte 880 injectors, 255 pump, 4" intercooler, Busher stage 5 clutch an a whole lot of track expierence
I figure with a solid tune on pump gas I should see no more than low 300whp with the stock springs and cams? Does anyone have any info on that? If so what have you run with stock cams on a 16g? My guess is the fastest the car could go is maybe 12.70s with a great pass? Any info would be awesome cams and springs are the first thing on my list after my birthday in may
Keep in mind this will be done on pump gas so the numbers will be limited especially without cams I have the supporting mods to give me some more room to grow with the cams and springs I'd like to see very low 12 second passes out of it on pump gas this season
Bump...anyone have any info?
I figure with a solid tune on pump gas I should see no more than low 300whp with the stock springs and cams? Does anyone have any info on that? If so what have you run with stock cams on a 16g? My guess is the fastest the car could go is maybe 12.70s with a great pass? Any info would be awesome cams and springs are the first thing on my list after my birthday in may Keep in mind this will be done on pump gas so the numbers will be limited especially without cams I have the supporting mods to give me some more room to grow with the cams and springs I'd like to see very low 12 second passes out of it on pump gas this season
), 2G pistons on 1G rods, Cyclone IM, Speed Density, eGay 16G, etc. Nothing crazy. So you should run pretty decent even on pump gas.
