Autometer LED bulb replacement... PICS!
God dammit, thers a lot of sanding to be done for gettin this thing in...btw i got da shavings on the numbers, and i got no clue how to get it out??? how shud i go about this...dont feel confident to open it all open...
Yeah there is a good amount to file. What did you use to make the hole bigger? I shouldve mentioned this before. But this is what I did with the second gauge to keep the shavings out of the face. I just held it upside down the whole time I was shaving. Shaking it to get the shavings out every once in a while. But its too late now since you already did it. But I dont know how to get the gauge apart :| . There arent that many shavings in the one gauge of mine that did get them in it. So Im not even gonna bother with tearing it apart. I take it you got the 9 LEDs' as well?
ya but theres shavings all over it... :thumbdown
Anyone tried the 6 LED bulbs yet?
YES i did.. and they turned out :thumb: :thumb: :thumb: Perfect IMO. However i do not have a scanner so no pics :cry: . They fit right on the old socket and i recieved them 3 days ago from superbrightleds.com in less than 48hrs from ordering. great buy IMO. special thanks to ZenkaiRacerDsM.
Just an FYI, I bought the 6 LED bulbs, and I have a fitment problem.
I have the Mechanical Autometer Ultralite Vac/Boost gauge.
I fit the light into the socket, bam, that fit perfect, then I installed the light
socket into the gauge, and problems...... :mad:
Apparently the 6 LED bulbs are too tall and hit the gauge armature inside the
gauge when the light socket is fully seated. :cry:
The needle binds up and the gauge doesn't work.
I'll have to get back to you guys on this, I just installed the bulbs before I left for work this morning.
Perhaps I may find a fix.....
maybe it has to do w/ the ultralite series as opposed to my phantom series guages :confused: :confused: :confused: I'm not doubting you, i'm just wondering how the two guages are different. I put my 6 bulb LEDs in a boost/vac guage as well so i'm stumped. I'm going to take pics and see if i can use a buddys scanner or a school scanner to give you all a glimpse. :thumb:
ok....so i'm a little bit confused here on the led part...is 6 6 small leds and 9, well 9 small leds... because i'm very confused on the led part of this...i was looking at the wedge bulbs and it looks like they only have 1 led? ...does any one have a part # for me
thanks
While we are on the topic of using LED's, has anyone managed to find a #74 LED replacement that works with the HVAC without modifing it? I have managed to find #74 blue bulbs which arent bright enough(looks dimmer than a blue bulb in an Autometer gauge like his first pic).
I did it to my HVAC panel. Only used one and got it from superbrightleds.com It's real even I think I got 8000mcd with a viewing angle of 45 degrees. I will take pics when I get the chance but right now I am trying to figure out whether or not I should just give in and buy Import Iintelligence Intelliglow needles or not :cry:
What a trip.... your gauge is virtually the same except for their exterior.
I will take a look at it again this weekend and get some pics thru the bulb mounting hole
so I can show you what the bulb is interferring with.
Thanks
Strm Trpr: couldnt you just shave off the ends of the LED's to give it the clearance it needs? just a thought....
I haven't really examined the situation yet, I just noticed that the LED's come
into contact with the armature of the gauge.
Really, you can shave the LED's, I'll have to look at that, but I think for now,
I'll modify the light socket with a shim and possibly cut away some of the
socket to accommodate the shims..... Just a thought....
Hopefully I'll have a fix by the end of the weekend.
Thanks for your suggestions.....
Peace
Someone Please Help Me Figure Out A Way To Get Out The Shavings, Its As If They R Stuck To The Glass N Where Teh Numbers R...like Static Or Something
Try a can of compressed air.
hey..
ive gotten my gauges changed from the stock black/orange to the reverse indiglow blue but the part that lights up the odometer is still orange. i was wondering if anyone knew the bulb number, whether it was a 74 or a 194 or something else. thanks a lot :)
lawrencehahn said:
hey..
same here, id like to know when u find out :thumb:
I was wondering if somone sould post a pic of a guage with one of those six led clusters in it. I put one of my extra 5mm blue leds of in the back of my guage last night and it looks like I will have to get something that has a little more output than 4000mcd :D
I'll take a picture tonight when I get home.
You can barely see the blue peaking around the face in daylight, and I stress barely.
But at night, man what a difference.
They're not quite as bright as the 9 LED cluster shown above, but I didn't want shavings in my gauge so I opted for the 6 LED Cluster which fit very well.
The only problem I found was the bulb cluster interfered with the boost gauge needle mechanism, so I can only put the light socket in, but not turn it to lock it. Works fine though.
Thanks, I am trying to decide if I want to put one of those 9 led clusters, 6 led clusters, or just make a custom kind of thing with all the 5mm leds that I have laying around.
