Automatic Transmission Upgrades
mini zilo
783
19
Jul 17, 2006
Chicago, Illinois
Well, I am about to start doing some automatic transmission upgrades:
TransLab Shift Kit
IPT end clutches
new manual valve
19,000 gvw trans cooler
My question is, is the trans cooler really necessary at this stage? Or should I wait until I upgrade my torque converter? Is the upgraded cooler needed if the only transmission mods are the shift kit, end clutches, and manual valve... Thanks
If your mod list is current, you shouldn't need a cooler, unless you plan on beating your car into the ground.
Even though you don't have your high stall yet, I would still recommend getting it--as it would help lower your transmission temp. down, which means it could increase the longetivity (sp?) of your transmission
