Automatic transmission TRANSDUDE PLEASE HELP
jasoncitrano
600
Jul 10, 2004
schaumburg, Illinois
Here's the situation, I have my motor sitting in my garage, and my transmission sitting in my garage. I got the engine back last night but now i'm a little confused on how the trans bolts back up to the block. I have an automatic so it's a bit tougher and not alot of people around here can help me.
The issue i'm having is bolting the actual flex plate back to the crank itself, and the actual order that all the stuff goes back... and also which order the torque converter and stuff goes in. Any help would be great and pictures would be the best.
Basically just need to know the order from crank to torque converter.
I FOUND IT!! WHOO HOOO ended up just calling john at IPT and what a nice guy.
For anybody else who is ever going to need this the order is.
Crank, then theres a 2 inch bushing, then theres a 6 bolt washer, then flexplate, then another 6 bolt washer then you bolt up the trans and the Torque converter and BAM your done!! :cool: THANKS JOHN and IPT
