Auto Tranny wont Shift.
abadz28
Feb 21, 2006
Beverly, West Virginia
I have a 1996 Eagle Talon 2.0 Non Turbo 420a automatic. It will not shift out of first gear. It goes into reverse fine and works in first just fine just wont shift. The overdrive light on the dash will turn on and off with the button on the shifter and I have tried shifting it manually and just by running up the RPM's and still wont shift any ideas.
Thanks
That is correct, I tried all gears with the od off then again with od on and the results were the same. Reverse and First work fine. Just cant get it to shift. I can run it up to 5000rpm and still wont shift. It will stay in gear the whole time.
Take out the TCU, take the cover off it and see if the board is ok...Drive the car with the tcu unplugged..You should have reverse and 3rd gear now....
