tranny wont down shift to second
mopar4Life
98
Mar 6, 2003
I jsut put in a act 2100clutch kit myself after i totaly fried the stock clutch when i first purchased the car it woulndnt down shift into 2nd untill car was under 20mph so i changed the clutch when it needed it now it still wond down shift untill below 20 mph and it hard geting 1st and somtims kicks shifter out of reverse i have bled the system and adjused the cluch pedal adjuster screw and added a longer slave push rod and it still is torturing me thanks for any help
Could be bad tranny syncros, when i bought my car I couldn't shift into 2nd, I ended up having to rebuild the entire transmission.
If you did everything right on the clutch swap, make sure nothing is rubbing on the shift linkage when you shift into 2nd / 4th / reverse. Sometimes lower radiator hoses or intake snorkels can block, push gears around or otherwise move the linkage. Hope that helps.
the friction point on the tranny is ike 2 inches off the floor so im thinking it might be the clutch master cylinder so i called the cdealer and they wanted 190 so i went to auto zone and picked one up for 60 might me the slave but donk know yet will find out and tell you guys
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Price is shipped USPS flatrate. Message 702-741-6987.
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $240 + shipping and PayPal fees* just replaced the upper bushing with...
  • For sale 4G63 Heads/ head parts
    Heads/ head partsNever ran ready to bolt up 1G head Ferrea dual valve springs/ retainers...
    • Dsm_canadian_mike
  • For sale 2g 2G Spare Tire Trim & Tool Pouch
    2G Spare Tire Trim & Tool Pouch $40 + shipping and PayPal fees* tool pouch has the tools...
  • For sale 2g 2G AWD Fuel Filler Neck
    2G AWD Fuel Filler Neck $65 + shipping and PayPal feesYou must be registered to see...
