auto tensioner retract fast?
nined2tsi
271
Sep 14, 2002
f, Alabama
Quick ? When you push the rod in the tensioner and release is it supposed to take a while before it releases all the way or does it fully release fast?
the rod should have a crap load of tension. if you are simply pushing it in without using a vice or the that special tool then i would say you may not have sufficient tension. I know i could push mine in with my hand. Of course i found this out after my timing belt skipped.
You have a 92 gsx correct? If your still using the stock one then i would definately replace it.
