Auto tensioner
RossY
627
Sep 27, 2002
Canton, Ohio
I just got an auto tensioner from someone on the boards and im just curious how to get the piston in the reset position. The tensioner isn't on the car so i was thinking maybe a vice would do? I don't know if there is anything else i need to do in order to get the piston retracted other than compress it.
whats with the :rolleyes: man. I asked this question because the amount of pressure my new tensioner puts out compared to the old one is way more. I mean i could actually compress the old piston with in my palm. So the reason i asked the question is because if i put the new piston end on the ground and push down, i still can't even budge it. I didn't know if this was normal or if there was something wrong with the new one. I mean, i knew my old one was bad but i didn't know that it was that bad.
I just got done doing a timing belt job on my car. I installed a brand new tensioner and didn't have the special tool. On my first try I didn't get the tension right so I had to pull the tensioner off. I tried compressing the pin by hand, then with large chanel locks, then tried using my jack as an upside down press. None of these worked, the tension is extreamly high. My manual says to use a vise, and to do it very slowly. I didn't have a vice so I use a 6" C-clamp.
i thought about a c clamp but mine are too small so im just gonna go witht he vice. Thanks for the input.
hey guys, i wonder how much can you get a new auto tensioner? some local shop quote me for $170 bucks OMG , is this really how much this thing is? mine i think is still o.k. though, i tried to press it to the wall, ground and i couldnt' even move an cm., the only thing that worked was a C-clamp :thumb: ,...oh, and uhm, everyone is right about the special too,.. you only need it when ur doing the timing belt the first time, the second time around, you can get around it without the special tool..
like 56 bucks. go to mitsupartsdirect.com ...email Mike Deal.
  • Wanted 2g WTB CLEAN HVAC PARTS
    Good condition , clean please no rodent infestation
    • ames905
  • Wanted 1g WTB: 4 Bolt Axle Cups.
    Looking for a set if 4 bolt axle cups for a 1g. Located in Canada.
    • blaster1812
  • For sale 2g 2G Manual Shifter Cables ( including NEW bronze bushings )
    2G Manual Shifter Cables $90 + shipping & paypal fees* I will be including NEW bronze bushings...
  • For sale 4G63 Race parts.
    It is the time to make room to improve the DSM, getting rid of some extra parts I no longer...
    • GST2012GSX
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
