Auto seatbelts not operating properly
90 Eclipse GS
123
Nov 11, 2003
Bellingham,
Okay I did a search and the last thread I found on this was in 2002 and it really did'nt answer my question. My problem is that my drivers side auto seatbelt and passengers side aren't working all the time when I open the door it doesn't release (come forward) like it should. The passenger side has not moved for a couple of weeks and the drivers side works when I turn the key off and remove it from the ignition and it sometimes works when I open my door with the key on or engine running. Sorry for such a long thread but this is very frustrating and I was hoping that their might be a relay or fuse????? Any help would be Greatly Appreciated......
Thanks Alot,
OK I have the same problem and with a volt meter i traced the problem to a black switch the autobelt is wired up too. to my knowledge it is what detects the open closing of the door and tells the belt to move. To test if your motors are bad or not. use your manual cranking tool to move the belt to the open mode. a haynes manuel tell you how to do this and i think even your owners manuel tells how to do this as well. and more questions just pm me.
nate
