Auto Kiggly Flexplate Bolts
pindlepiper
146
9
Jul 29, 2008
Indianapolis, Indiana
I am looking to see if these ARP flexplate to crank bolts will work without modification on a 6 bolt engine mated to a 2g auto transmission. I am using the Kiggly 6 bolt in a 2g auto kit. I already purchased 4 converter bolts off of kigglys website. Here is the link to the flexplate bolts. EXTREME PSI : Your #1 Source for In Stock Performance Parts
Will they be the correct length using the kiggly flexplate?
It says bolts from a 1g 5 speed, or 17mm long.
Honestly send kiggly an email off of their website if you're not sure. I know Kevin/Erin would be more than happy to help, and would definitely know what you'd need.
It looks like the people that are using the 1g 5 speed bolts are having to modify them by either cutting threads or shaving the head. I am basically wanting to know if these will work without modification. I have emailed Erin a few times with different questions regarding the correct bolts to use and she suggested OEM for the flexplate to crank. I just stumbled across these ARPs and was curious of their fitment.
This is a very old thread now. But I'll come chime in and say I used the ARP ones and they worked perfectly with the Kiggly flexplate.
