- Ownership Status
- Currently Own
- Year
- 1997
- Model/Trim
- Mitsubishi Eclipse GSX
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- Holset Billet 7 Blade HX40/ 16cm Divided Housing/ Shearer Twinscroll T3 Exhaust Manifold/ (2) Tial 38mm Wastegates/ VRSF FMIC/ NGR BOV/ FIC 2150cc Injectors/ Walbro 450Lph Fuel Pump/ GSC S2 Cams/ 3" V-Band Downpipe/ HP Boost Controller/FFWD Triple F Bracket/ 1G Mishimoto Aluminum Radiator
- Mods-Engine
- 6 Bolt Block
Wiseco HD 10:1 Pistons (22nd Wristpins)
Manley Turbo Tuff Rods (22mm)
ACL Race Bearings
Kiggly Main Girdle
ARP Main Studs
ARP L19 Headstuds
Balance Shaft Delete
Fluidampr Harmonic Balancer
Felpro Permatorque MLS Headgasket
2G Head
Kiggly Beehive Springs
Ferrea Competition Plus Valves
Ferrea Bronze Valve Guides
Supertech Valve Seals
3g Lifters
Kiggly HLA
GSC S2 Cams
- Mods-EMS & Logging
- DSM Link V3
AutoMeter Gauges - Boost/ Water Temp/ Oil Pressure/ Voltage
MTX-L Wideband Air/Fuel Ratio Gauge
- Mods-Drivetrain
- Kiggly 5-Friction Front Clutch Pack
TransLab TL-175 Shift Kit
Borg Warner Frictions
Kevlar Kickdown Band
Road Surge Shift Box
3G Tiptronic Shifter
Rebuilt Transfer Case
LSD Rear-end
- Mods-Handling
- Tokico HPK Shocks & Springs Kit
Outlander Brake Upgrade
Stainless Steel Brake Lines
Enkei EVO 9 Wheels
Front Subframe Solid Aluminum Bushings
Rear Subframe Solid Aluminum Bushings
Prothane Full Polyurethane Suspension Bushings
