1G AT with AEM EMS Series 1
sleeper1ga
160
14
Oct 4, 2014
Chicago, Illinois
Has anyone on here used AEM EMS to shift their car, if so I would love to know what you need to do to set it up. Also has anybody been able to set up a way to use a manual shifter but also be able to switch to being controlled by the ECU/TCU(Will the road surge box allow this, I don't want buttons or paddle shifts, I am looking to run a ratchet style shifter).
Thanks, Sleeper1ga
You can run a ratchet shifter without electronic aids. Search for the Kiggly manumatic shifter mod(it's on his website as well) and do that, in conjunction with a ratchet shifter will give you full line pressure, instant shifts. It's also absolutely the most fun setup for a DSM I have ever driven, including 5-speed DSMs. However you will need to fab up a bracket for the ratchet shifter, but I'm sure you already knew that.
Sorry if my post was confusing. I want to be able to switch between ECU/TCU controlling the car and also be able to have a ratchet shifter for when I'm street driving(I know that sounds backwards but the best shift for drag racing would be one that is already programmed). As far as I am aware the kiggly mod is always manual shift and cannot be used with ECU/TCU control. I'm looking for the same concept as many of the shift boxes where you can change from programmed shift points and manual control, but I want to use an actual shifter not buttons.
Thanks again, Sleeper1ga
Couldn't you just install a ratchet shifter with the stock TCU? That what it sounds like you want.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
