zachakagoat
- 1,154
- 6
- Feb 7, 2003
Prairie Grove,
Arkansas
Or you can do this.You must be logged in to view this image or video.
Strip everything, clean, fill, paint.
If I had pulled the entire engine in sure I would have. Maybe next winter during a big rebuild I will do that. I'd like to do a fuse box relocation a well and replace everything with a bulkhead connector like the LSX blocks use to the cab of trucks. I was gonna remove my air con while I had everything out but I'm gonna try replacing the valve pressure relief valve first to see if it solves the problem. If it is still messed up ill just pull the belt and remove it another time.
Where is the best place to pick up window weld? Gonna fill my driver side roll stop while it is out.
Now I just need a battery.
that us what separates the men from the boys. Haha. TCs are kinda starting to look a lil better... If you count leaning more towards a XB a better look.
