Are these SuperTech Valve Springs overkill?
JCL84
110
5
Jun 13, 2012
McHenry, Illinois
So I have these valve springs that came with the car I purchased but I am thinking that they are overkill for the goals I have in mind. The specs on these things are on the chart below. Part# SPR-M1009D. I have 272 cams in mind but not sure which brand yet. Do you guys think I need to downgrade a little bit and get different valvesprings?
Oh and the rest of my mods are 750cc injectors, MHI 20g turbo, Punishment racing FMIC, Fuel pressure regulator, Full Blown Dual fuel pump hanger, 3in exhaust, 6 puck clutch, I will be using DSM link v3 but that I still need to purchase.
I am probably going with bigger injectors because I want to run E85.
I dont see a reason to ever downgrade a valve spring. Or at least i have never heard of that being done. It just gives you more peace of mind: no valve float for you! Plus, lets say you want kelford's 272 camshaft. You will need heavy springs. I mean, theyre not mandatory but i certainly would want a dual spring or something much stiffer than stock with a Kelford 272.
Keep 'em
Im worried about one thing if I install these. Ive seen people get very technical when installing valve springs like measuring for valve spring height. Then I have seen people just slap valve springs on without doing any measuring. Do I have anything to worry about if I just install them as is?
With as much seat pressure as they have, installing them a bit tall will lower them, You should measure them so you know what pressures you have.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
