Resolved Are Eagle and Manley parts compatible?
shshfbdicn
Mar 27, 2024
alburtis, Pennsylvania
I have a 2.3 stroker dsm and I recently spun a rod bearing and since Manley doesn't make their standard 800 dollar stroker crank anymore I am wondering if Manley rods would be compatible with a eagle crank. I want to stick with manley but I don't need to spend 1800 on a crank.
I have a 2.3 stroker dsm and I recently spun a rod bearing and since Manley doesn't make their standard 800 dollar stroker crank anymore I am wondering if Manley rods would be compatible with an eagle crank. I want to stick with manley but I don't need to spend 1800 on a crank.
Not sure if this is a real question or not. Those parts do not know each other exist. As long as it is a 6 bolt rod on a 6 bolt crank, or heaven forbid 7 bolt/7 bolt, that is all that matters.
Yep it's definitely a real question considering I don't wanna spend 800 dollars and end up getting the wrong crank but thanks
They are all machined to factory specs on the rod and main journals. It will not matter whose name is on the crank. I am not sure why you would think that would matter.
It is that simple, 6 bolt or 7 bolt. Order what you intend to use.
Parts are designed to be interchangeable and fit with other factory parts, thus they must fit with each other as well :).
I run a Manley crank, Eagle rods and Wiseco pistons.
