2G Are 2G ABS Hydraulic Modulators Interchangeable? What about the ABS ECU’s?
VT_4G63
5+ Year Contributor
81
34
Mar 23, 2021
Saugerties, New York
Hello,
As the title states, I’m trying to determine if 2G ABS Hydraulic modulators are interchangeable. I have a 96 Spyder GST with a Bosch ABS ECU and coinciding Bosch ABS Hydraulic Modulator (the box that sits behind the driver side headlight).
I’ve determined the motor in the modulator is bad, and it looks like the ABS ECU might be bad too. I was going to replace both, however I can only find Nippondenso replacement modulators. They appear to be the same part, but not sure if I can use it with a Bosch ECU or if my chassis can take the Nippondenso unit in place of a Bosch unit. Also, if I had to, could I just switch both the ABS ECU and ABS Hydraulic Modulator over to Nippondenso even though my chassis came with both Bosch units from the factory? I know 98-99 chassis have the ABS ECU on the modulator, I would t be using one of those, I would be using a modulator with the same layout as the original unit.
Thank you
