apexi safc2 problem
viperbenz1
249
3
Dec 28, 2008
boston, Massachusetts
hey guys i have installed my safc today , the trottle is at 100% and when i give it gas it goes to 90% also it said on the paper that the orange and pink wire are for air fuel ratio,
when i plued them i end up having the check engine lights on so i took them back out until i figer out whats going on:confused:
please help me,:ohdamn:
I thought it was a pain in the butt when I installed mine on my 95 AWD and I didn't think the directions weren't to clear so I would check over everything and make sure its all right...
everything seem to be fine , but this is my problem pink wire Air Fuel to ECUOrange Wire
Air Fuel to Sensor
, what sensor?
i already did hook up the pink wire to the ecu but i dont know where the orange wire goes
Taken right from the link I posted. All you had to do is read!!!!
Cut the wire at terminal 90 in half but leave enough on both ends to play with. Attach the ecu side of the end of the cut to the pink Super AFCII wire. Connect the harness end to the orange Super AFCII wire.
