need apexi safc2 settings for 1g
1991eagleawd
88
Jul 5, 2011
toronto, ON, Canada
i have
Mild head port, 550 injectors, 190lb/h fuel pump, rewired fuel power lines, fmic, Apex i SAF2 fuel controller, Apex i turbo timer, Auto meter boost. wide band COMING SOON.
can someone let me know what plus minus i should be running. i rather be on the richer side of the scale. thanks in advance. (this is temporary until i get new turbo kit and wideband) just need to know im running richer than lean.
I used to run a safc2 on my 1g, with stock injectors, 255 pump, and a small 16 i had mine set on +14 across the board. but when i upgraged to a 20g and 550's i had to pull mine close to zero too. i was running a hacked 1g massair though. I wouldn't try to tune on a car without a wideband! :nono:
i agree, but.......i cannot get one till early august. so im looking for some settings to get me there safley. (richer)
I guess I left out the part about also having 550cc injectors. The 2g MAS pretty much cancels out the larger injectors. You should be able to find one for pretty cheap, at least a lot cheaper than a WB.
  • Wanted 95 eprom
    Looking for 95 eorom
    • GhostTypeP0300
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
