Apexi Safc Airflow Signal 0.0??????
4g63t
1,568
13
Aug 14, 2005
North Iowa, Iowa
I Just hooked up my Apexi safc last night and i was looking through the menus and the air flow was at 0.0 I drove it up the block and it did not move. I looked at the vfaq again and it was hooked up right with the ornge wire to the harnis and the pink wire closer to the ecu clip in the third to the left wire I think it was green with a blue stripe on the longer sized clip. Please could someone tell me what im doing wrong? I need a crash corse on how this thing works. What are the yellow and white wires for it did not tell me in the vfaq>?
The problem you are experiencing is not a problem at all!
Air flow signal will always be 0.0 because you are not using that channel in the Safc, instead go to your menu and get the reading from KAR or Karman Vortex, that will be the reading and you will see it in Hz.
Hope this helps :dsm:
