Apexi safc
overboosted1g
743
6
Jan 13, 2010
washington, Michigan
So I'm in the process of installing my apexi safc in my 1g, I was using the vfaq tutorial and noticed that the pins on my ecu connectors don't correspond correctly according to the color chart. Like the power wire says it's on the second row and 2nd from last but when I try the test light it gets no power. Also the wire is not red with black stripes it is just plain red. Should I just use the color diagram.
Sent from my HERO200 using Tapatalk
AFC should turn on with the key without ignition (ecu plugged in). At least that's the way it works on my Apexi Neo. It enables you to tune the car (i.e. injectors dialed in) before you actually run it, which could save you an engine blow-up if you kept the earlier driver's set up and ran it directly. Also, per your wires, could it be that you have a non-matching extension? Sometimes the SAFC comes with the wrong extension and it messes up the colors.
Here's the thing if I ground the afc and hook up the power wire to the battery it works but the power wires on my car don't match the vfaq pinout. Should I just probe the car's ecu harness until I find the power wire.
Just so you know, the diagrams are looking into the back of the connectors (side where wires are comming out of em) not he pin side where it connects to the ecu. IF the wire colors dont correspond, you are doing it wrong.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
