Anything else??
Not to bash but good luck with the turbo. There are a ton of posts on this topic and the whole "staged" haha upgrades on what you need. SEARCH please
BTW don't use that oil feed line. I've read some past threads with ppl saying not to use it. Get an SS line right away. Also check the manifold to turbo bolts (4-10x1.25) and see if they're OEM or @ least OEM quality (grade 10 or higher) cause I've made the mistake of using aftermarket bolts other than OEM and every single one has taken a dump on me i.e. threads sucked, snapped, yada yada. Make sure to use anti seize on all the bolts on the turbo except for the water lines and oil feed and drain.
Whats wrong with that turbo? Isnt it a stock evoIII16g? Also it says it has a 1 year warrenty. Is it a cheap knock off?
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
