anyone with bullseye power turbo .....helpppp with oil return line
ihatedsms
352
Dec 4, 2004
berlin, New Jersey
i need to find out what lines and fitting i need for the oil return line....
i orderd an ss oil return line from extreme psi,
and it dose not fit!, the fittings hit the motor mount not allowing me to put it on, it is like directly above the motor mount and im stumped on what to do......
so if anyone has any info or can help me out let me know....
thanks
oh yea its a bullseye power 50 trim, on a 1g
You can notch the motor mount to clear the line, most of the lines are like that.
Chances are you got your adapters mixed up.. I think I initionally put the straight one on the turbo and had it hit the motor mount. Then I was like "DUH" and put the angled one on the turbo and all was well.
Angled or not, both will hit the motor mount. Either notch the mount untill fits well (like I did) or you can order this(saw it after i ordered mine):
Run this flange:
http://www.atpturbo.com/Merchant2/m...OD&Product_Code=ATP-FLA-009&Category_Code=FTG
With this fitting:
http://www.atpturbo.com/Merchant2/m...OD&Product_Code=ATP-OIL-003&Category_Code=OIL
this should give you much more clearence around the mount, and you might even be able to use the straight fitting of this and the 45 fitting on the drain. Hope that helps
Ok.... I guess I've never done this... I believe I even have the extreme PSI oil return. I didn't want to mess with making my own...
ok so it turns out that i definitly had to cut the motor mount a bit, even with the 45 degree fitting it still hit. but not as bad with the straight fitting.
so im good now, thanks everyone for the info
This is the AGP oil return kit for Garret style oil drains.
this is the quickest installing oil return i know of.
Im not sure if AGP still sells it though.
It alows a Hacker free install!
I tried giving AGP my money but every time I called they said "sorry dont have the flanges in stock" or something along those lines... oh well:(
