anyone use these ball joints?
The listing says it only fits honda and acura, The one you want fits into the top of the knuckle where it bolts the the upper control arm.
You can't change balljoints on a 2g. Only on 1gs. The 2g you need to replace the arms.
If your looking for alignment, look for ignalls kits.
I did a t-belt job on a friend's 2G and she had these same balljoints in her upper control arms.
They can definitely be removed/replaced.
You just pull out a snap ring, and press them out on a 2g.
Mine has the camber adjustment on the other end of the upper a-arm instead of the offset balljoints; the joints that bolt up under the hood are eccentric. It works really nice. I would recommend you look into getting those kind instead.
