speedy_talon28
- 364
- 3
- Apr 1, 2006
elkhart,
Indiana
we have 89 91 93 or 95 octane. you mean you can only choose 91 octane? well, you can always use nx (nitrous oxide) or (nos) octane booster. if that's your cup of tea
The higher the octane the lower the fuel mileage. Choose the lowest octane gas that doesn't give you pinging. Or, if your paranoid, run what you are running.
Where'd you get that info? If the higher octane allowed you to run more boost and then you couldn't avoid being a lead foot then yes, I'll agree.How's the toluene working out for you so far? Notice anything different?
I added 1 gallon of toluene to 13 gal of pump 91 (which raised total octane to 92.6). Butt dyno says it's hitting harder north of 4k, especially on upshifts from 2-3 and 3-4.
Logged a couple of runs preliminarily, and am seeing 2* more advance at 6.5K (which is where I usually shift anyway...timing drops off for me above that). Will log a few more runs to see if it's consistent. Then I'll turn the boost up and see how it goes.
I also found some 111 leaded gas locally. I'm gonna try some of that next tank as an additive, as it's way cheaper than the toluene ($4.45/gal vs. $15!). Three gallons of 111 for the same price of one gallon of toluene will bump me up to 95. Will report on any differences. And no, I don't have a cat to clog up
That's a great price for 111. Makes better sense than using the toluene since it has gotten so expensive. Keep us updated.
Good work.
I'm not going back to toluene, that's for sure.
Yay! This thread is getting technical!
I am interested in your experiments with acetone.
Toluene does not atomize very well in cold weather. If the Ambient Temp is over 70*, it will atomize better....R/M2 octane on toluene is 114 raw.QUOTE]
As mentioned some acetone mixed with the toluene may help it to vaporize better. So far my impression of the acetone added to the gas is very positive. Car seems to run smoother and quieter.
Gsxtacy: Have you tried buying your Toluene in 5 gallon cans?
I myself buy it in 5 gallon cans @ $6.89 a gallon.
!! How funny... Earlier today I finally found a place that sells Toluene in hawaii! It also happens to be Sherwin Williams. It was like 16.00 for a Gallon, and for a 5 gallon "Pail" it came out to 7.44 a gallon including tax. Also, the dude just gave me the contractor price. So I thought what the heck, why not just spend 20 more bux and get 5 gallons just incase I like it!
I can't wait to try it out. See if it makes a difference in my timing curve/knock issues, and I'm going to lean out the a/f from 10:1 to 11:1 and see what happens! Right now, I KNOCK at 10:1 a/f 20psi around 5.5k rpms and up on 92 OCTANE. I'm going to do 1 gallon mixed with some ATF or Marvel Mystery oil... I hope its okay to skip the mineral spirits that you should put in.. like Kerosene...
) but have run as high as 50% with no problems what so ever.
