anyone else ever have this issue?
95formula383lt1
Jan 18, 2012
Port Charlotte, Florida
Decided to change the oil an filter after driving it for a month. Previous owner gave me a filter so said screw it. Ran to the store to grab some castrol gtx 10w-30 conventional oil ( love castrol run it in my lt1 ). Start the car up and drive away after oil change and after letting it idle for a few mins (filled filter before install of course). Get to the red light car stalls oil light comes on. Start it back up everything is normal no issues drive away. Stop at the store car sits maybe an hour. Start it up drive away about a mile down the road stalls again check engine light flashes. Start it up drive away no issues. WTF could this be? Theres a random tap up on the top end after oil change. Does not do it all the time and does it only at idle it comes an goes. Not sure if previous owner used conventional or synthetic so not sure if that would be the cause. I just hope it goes away and its nothing serious. :pray::banghead:
Did you whack the oil pressure sender while changing the oil? Could be a bad wire, bad sender, or something was plugged and now it's dislodged.
no didnt whack anything just carefully put the filter on and took it off. Oil that came out was pretty clean and didnt have any issues before. Had the valve cover off last month changing the gasket all looked clean there to no sludge.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
