ECMlink Anyone care to look at my log?
Slo2gen
768
32
Apr 26, 2005
Upstate, South Carolina
Having some issues with boost taper as well as I have melted 3 AC fans even without running the AC. The car runs good otherwise, however I have recently run into issues with melting the fans. I recently purchased a PTP turbo blanket and sock for the FP manifold. Current setup is a ETS FMIC, Mishimoto radiator and fan shroud (2 mishimoto fans and 1 oem ac fan), 20g, ECM link, Evo III Intake manifold, FIC 2150cc injectors, Walbro 525 Fuel pump, that should cover what should effect this issue. I have other mods but if I need to post them I can. I appreciate everything, just trying to make sure that I have everything in order before I have a remote tune done. I just am waiting on the Frontline valve cover to install my catch cans.
I can't pull up your log. Try just adding it as a photo but not from dropbox, directly from the log on your computer.
Something is up. Your GM3bar is always reading 20 lbs boost, even at 1% Throttle. Is it set up correctly?
I could pull up your log when you load it that way, thank you.
Marty
Zero out the timing slider
Under Misc, uncheck disable airflow smoothing w sd operation
DA, MAF slider & global needs work but they'll figure that out
Does it idle alright with zero deadtime?
You'll want to input battery offset for those injectors in DA, INJBATTERYADJ
You don't need to change anything in speed density VE table since you're running maf
Made the changes and got a decent 3rd gear log.
The log is only idle and it doesn't look great. Let your tuner tune it. But you can fix the throttle% and tps for now.
That is the plan, the biggest thing I am checking through these logs/post is that the boost taper and numbers look ok before I stress the car with getting tuned. I appreciate you taking the time to look at it. If it matters I will be having Mr. Jewer doing the remote tunes. Just waiting to get it tuned on the valve cover and catch cans now. As far as TPS I did run the TPS configure a couple of times, when the car is off it reads 0 and then WOT is 100 once I drive the car it moves to 1% to 100%.
I have the same issue with the tps. Set the tps with the car running. I believe at WOT the isc should be at 120.
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 2g 2G Auto Shifter Cable ( GSX/GST )
    2G Auto Shifter Cable $45 + shipping & paypal fees* GSX/GSTYou must be registered to see...
  • For sale 2g 2G Auto Shifter Base
    2G Auto Shifter Base $40 + shipping & paypal feesYou must be registered to see element.
  • For sale 1g Mishimoto radiator
    Mishimoto X-Line Aluminum Radiator | 1990-1994 1G DSM (MMRAD-ECL-90X)
    • william
