Any idea what this thing is?
4gfun
Supporting VIP
2,012
56
Dec 10, 2007
Ask Me, Virginia
It is just hanging there with one side connected to the FPR and the other side connected to the IM.
Is this the BCS?
Thanks
that is your FPR and it's hooked to your fuel return I believe pl use that to tapinto for boost gauges
follow the rubber/silicone tubing from the cold side of your turbo that will be your BCS
if your turbo is like a t25 there should be a small rubber hose that runs from the intake side or your turbo to a device that looks similar to that and that will be your BCS
if what I researched is right your's is and i4 right? it should only have 1 turbo if if it's like the the TT 3000gt VR-4 then I don't have a clue how they set those up whether it's one BCS or 2 IDK :cry: my google-fu is rusty today
Is this located over by the Air filter, or over behind the IM near the firewall?
whats a BCS?
sorry, but i really dont know, kinda new to the dsm thing
Boost Control Solenoid.
The solenoid pictured is either the evap solenoid,fuel pressure solenoid or boost solenoid. Trace the vacuum line attached to it to see where it goes. IIRC the line for the BCS should go to the nipple on the wastegate actuator.
