Any dealings with a "Fail-Safe" Thermostat?
gsxtacy
1,157
26
Apr 29, 2002
Clovis, New Mexico
I recently ( 3-4 months ago) replaced the original Thermostat in my 98' GSX with a "Fail Safe" Thermostat. Fail safe meaning, upon failure the thermostat will stick in the OPEN position. Today (Christmas) I drove 18 miles to my Grand-Parents house to have Christmas lunch. On the way I was cruising 70-75 mph and about 14-15 miles into my trip I glanced at my gauges and noticed that the temperature was above normal
( 9 O'clock ) pointing towards 10-11. I observed that it wasn't climbing, but instead just holding steady, so I reached over and kicked the Defroster to HIGH, Climate to FULL WARM and it slowly decended towards normal. Well I finally made it to Grandma's house, parked the car and popped the hood.
All was well, no leaks, no boiling. Nothing seemed out of the ordinary. I let the car sit for awhile and cool off a bit, went inside and ate lunch. Well, I came back outside to check on the coolant level. Low. So I went to the local convience store and purchased some $8.99 50/50 coolant. Topped off the radiator and cranked the car to get the thermostat to open and top off the system. It seemed as if the thermostat NEVER opened, the coolant I poured in previously just flowed away. I decided to drive the car home gently, no boost, no speeding, just ordinary driving. 18 miles no temp rise. Stopped off by the mother-in-law's house to pick up the gifts we had opened earlier in the morning, and proceeded home. 10 red-lights later I am noticing the temp was getting back to 10-11 o'clock. Get home and check the coolant again. Low.
WTF? What do you think? Is my new "Fail-safe" thermostat FAILED? I am thinking its either that or my Radiator cap isn't holding the 15psi that a cooling system should, OR a combination of the radiator cap/thermostat. No steam, no boiling, no coolant in the oil, no coolant out the exhaust. Anyone wanna chime in with a similar experience?
thanks.
gsxtacy
I've had 3 fail safe t-stats fail 3 times in the CLOSED position, they suck ass. Two on my Grand Cherokee and 1 on my GSX, I just buy the Stant regular t-stats now and never had a problem.
Do you think my Fail safe failed? I think so, changing that POS tommorow!! Does local OEM parts stores have radiator caps for DSM's? Satan won't be open till monday.
thanks
gsxtacy
  • For sale 2g 2g GST auto trans case
    2g auto trans case. With bearing plate and end case covers. Good condition. Trans was like...
  • Wanted 2g 2g radiator support
    Im looking for a radiator support if anyone has one
    • Fundsm
  • For sale 4G63 3 inch Magnaflow SS high flow cat. CA approved.
  • For sale 4G63 Race parts.
    Brand new seal in box Kigglys HLA 175$Kigglys 12 tooth billet crankshaft triggel setup 250$...
    • GST2012GSX
