ECMlink Antilag..
A couple things to check:
Set your ALS TPS value to something reasonable that you'd most likely exceed while launching the car.
The "Use launch control with RPM" value is < the "Launch limit" value from the RPM/TPS screen. Set the value on RPM/TPS screen to 500 RPM higher than the value on the ALS screen.
If you have a value set for "Clutch cut rev limit" on the RPM/TPS screen, make sure it's higher than both the values you just adjusted.
The "And speed" value is > 0. Set it to 7mph.
The "Use clutch cut with speed" value is > 0. Set it to 20mph.
It should work then. If not, post up a log.
