1g ecmlink antilag
wishful_laser
242
Nov 25, 2003
springtown, Texas
I have a 1g dsm with ecmlink v2.5 hooked up and working. My question is that I tried to setup my antilag and its not working. I need to know if im setting it up wrong or do I need to do the clutch cut wire thing. What am I missing. Any and all tips would be appreiciated. This is my first time playing with link. What settings do you guys have for your antilag.
Are you trying to use anti lag or NLTS? The clutch wire is only used if you are going to utilize the NLTS function.
As far as turning anti lag on, of to the knock/als tab, and click the little "enable antilag" option.
Going to be using both but the antilag is on i changed rpm to like 4000 just to see if it worked
It just revs up like normal didnt know if clutch wire mod had to be done for antilag to worm whats your settings at
Antilag is for low rpm to help get the turbo spooled quicker. Being that you have the setting at 4k rpm, that sounds like your launch limiter (aka. 2 step) that helps build boost while sitting still for launching the car. I don't think the clutch wire is required for that. I'll have to look through the tabs to remember how to enable it...unless someone jumps on before me.
  • Wanted 6 bolt NT water pipe
    • chrisman287
