antifreeze leak.
risnerry
Oct 16, 2008
knox, Indiana
so somewhere I'm leaking antifreeze and its spraying onto all my belts which is flipping it everywhere. I've cleaned it all down and let it run to see where its coming from and i still cant find it. I've checked my hoses that i can see.. is there any hoses i cant see? or what else could it be? I'm pretty sure it's not my water pump also, it's pretty clean back there. it seems to be more toward the front/middle.
Yea check the water pump there designed to leak out a pin hole when they go bad that's the the closest to the belts. Are you losing coolant.
