Anti-Lock Brake light...
BGuinard
55
Feb 26, 2010
Hawley, Pennsylvania
Anti-Lock light is on always... Whats up with that? Any theories dudes and dudettes?!:hmm:
BRAKE, not BREAK. (Edited your title to reflect spelling correction.) :)
There could be a few things wrong. If a wheel speed sensor is not reading correctly, then it may send the ABS system into a fault. The other cause of an ABS light is an inoperable ABS module. The module itself is ridiculously expensive and buried in the front bumper. A diagnostic is needed to determine which of these is causing the problem.
sometimes when I attempt to used my datalogger and the ECU goes into the diagnoistic mode, it sometimes throws my brake light. You could also try just removing the negetive terminal for a couple minutes to reset your system and see if it goes away. If not then you might have a more severe issue as stated before.
Thanks man I appreciate you keeping me from looking like a Nimrod. HAHA:thumb:
my car was doing this too for like the longest time i just kept tryin to reset it and finaly it quit coming on and worked again im not sure if its same for urs but turn the key to the "on" and the light will flash and hold the break for a little bit and it should reset it.
