anti-lock brake light on
talonawd94tsi
104
Jun 25, 2002
Denton, Maryland
what could cause the anti-lock brake light to come on as soon as the car is going like 10mph. The light stays on until I turn the car off then comes back on once the car hits about 10mph again
I know this is a question that have many answers but what do you guys think?
Have the ECU scanned. The fault code will tell you what the problem is or give you a better idea on what is wrong.
When the ABS passes the start-up test (i.e., blinks four times when you start the car and then stays off), but then the light comes on and stays on after you have rolled about 20 feet, it's a wheel-speed sensor. First check to see if one of them is out of place or has gunk between it and the rotor. After that, you need to find someone with a MUT-II scanner to learn which sensor is out, because OBD-II scanners can't read our ABS.
- Jtoby
