Another turbo selection thread-sorry
AuntiesTSI
277
Mar 8, 2004
Omaha, Nebraska
The setup I will be running will include what is in my modlist and also 272 comparable cams as well as 880cc or larger injectors, DSMlink, and a different manifold etc.
Im lookin for somewhere around 500 hp on race gas and a decent streetable number on pump maybe 400 or so since I drive the car alot when it runs
I was looking at a GT35R which is good for the numbers and since it is larger the little bit of lag would also help since I am, unfortunately, FWD.
The Garrett GT series turbos are also pretty interesting, I was looking at he GT14, which Im pretty sure is what was on the 500 hp galant on 1320video.com who is a good friend of mine, as well. It seems to have a lot of the same characteristics of the 35R with a cheaper price tag.
Also while i was lookin at these they had a few different types of compressor covers to chose from like the port shroud and the T04S, which is best for what I am looking for??
Any other application suggestions and comment are welcome, OTHER than get AWD:) . thakns alot
When companies take Garrett wheels and put them in Mitsu housings so they can bolt on, they generally do not flow as good as the full Garrett units. You might want to look into Forced Performance turbos like the 3065. These are bolt on units with completely custom-made stainless turbine housings. Either an FP turbo or full Garrett will flow the best. And if you're going with a full Garrett, I suggest the GT3076R.
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
