XC92
5+ Year Contributor
- 1,654
- 376
- Jul 22, 2020
Queens,
New York
I'm going to be dropping my trans within a month or so now that it's warming up here in the NE, and finally try to fix the issue it's had where it pops out of 1st gear. I had hoped to fix this last year, but for various reasons I wasn't able to and had to reinstall the trans before I could get to it.
Anyway, I'll hopefully know what's causing this and what else needs to be fixed once I open it up. But in the meantime, I'm just wondering what's the most likely cause, given the specific way in which it pops out.
Sometimes, it doesn't pop out at all and stays in until it's time to shift into 2nd.
Sometimes it tries to pop out but if I hold it in it'll stay until it's time to shift to 2nd.
And sometimes it pops out no matter how hard I hold it in, and I have to start in 2nd, which is not good because I have to slip the clutch so as to not stall the engine. Major pain in stop and go traffic.
At no point do I hear or feel any grinding. There was some grinding a while back, but that was because the clutch didn't fully disengage, and I've fixed that (temporarily, but that's another matter). There's no problem getting into 1st with the clutch fully disengaged. It just doesn't stay in most of the time.
Does this sound like a shift fork or detent ball/spring issue? Maybe these aren't the right words for them. I mean whatever keeps the trans in a given gear once the synchros have done their thing and the gear, sleeve and hub are fully engaged and under load. Could it be as simple as these being worn out or broken, which I believe is a much simpler fix than a bad synchro, hub, sleeve, key, etc.?
There was no play in the input out output shafts and the locknuts are tight.
I'm not looking for an actual blind diagnosis, of course, just what these symptoms likely point to.
