another cop question??
Since your using your '95 ECU on a 1g CAS you need to rewire the primary ignition wires either at the ECU or the Ignition Power Transistor, its your choice the wire colors remain the same.
You need swap the Yellow wire from ECU pin 54 with the Yellow/Red wire from ECU pin 55. Heres an ECU pin out if your unsure which pin is which... 2g ECU pin out and wire color
Hope that helps ya get your car started.
:dsm:
  • For sale 1g 1g turbo oil feeds
    1g TD05 oil feeds. Found another box. Have 15 feeds. Have no return lines left. Been running...
  • For sale 2g 29 tooth auto speedo
    29 tooth 2g auto speedo. Good condition. Price is shipped. Message 702-741-6987
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
