Another clutch bleeding question, slave releases with pedal on the floor
bertrenolds
254
3
Aug 21, 2010
savage, Minnesota
I just replace my clutch slave and master and I use the pump the slave arm to get air out of the line to get it started trick. Now with a helper I open the slave bleeder nipple and have the helper push the pedal to the floor and the slave moves the fork all the way in but then before I can tighten the bleeder nipple with the pedal still on the floor the slave moves back in releasing pressure on the fork after bleeding several times. The only thing I could do was tighten the nipple fast or I guess I could hold the fork so it doesn't release so that I have to pull the pedal off the floor. I adjusted the master correctly, turned the shaft until I couldn't push in the slave and then turned it back counter clock wise to a point where I could press the slave again. Only thing I havn't replaced in the system is the rubber part of my clutch line so could that maybe be the problem? I was also thinking of getting a speed bleeder to see if that helps. I do have a ACT2100 clutch now and maybe that is to much pressure for the system to hold while bleeding?
Sounds like you may need to adjust the master cylinder adjustment rod.
<iframe width="420" height="315" src="http://www.youtube.com/embed/vYJxQyjIhUw" frameborder="0" allowfullscreen></iframe>
It sounds like you are doing it wrong. Your helper should push the clutch to the floor while the nipple on the slave is still closed to build up the pressure. Then open and close the nipple to let the fluid/air/pressure out, and repeat. The fact that it is an aftermarket clutch has nothing to do with how you bleed it.
Here are some how to's:
How to Bleed a Hydraulic Clutch - Team Rip Engineering
http://www.dsmtuners.com/forums/articles-drivetrain/213503-how-properly-bleed-your-hydraulic-clutch.html
http://www.dsmtuners.com/forums/articles-drivetrain/60319-how-bleed-your-clutch.html
Slave Cylinder for the Clutch
Good to know since it seems like everyone else says to open the bleeder nut and then push and hold the pedal. And I am positive I have the master set correctly because I did fallow the video that was posted above. I can currently drive my car and the clutch works but I thought it was strange the slave cylinder rod was getting pushed back into the slave with the clutch pedal still pushed to the floor. I will have them push the clutch pedal to the floor and then release the bleeder nut and see if that works.
This http://www.teamrip.com/how_to_properly_bleed_a_hydraulic_clutch_info.html is exactly what I needed! Thanks. I can't believe this isin't a VFAQ?
