We're on Boost
- 3,047
- 1,468
- Aug 25, 2007
Seattle area,
Washington
Right it's 14.1 AFR for e10. I don't think we want to do that though. Because everybody for the last 50 years is familiar with the AFR numbers for straight gasoline. Seeing e10 AFR numbers would look funny, it would look like it's a little off. You know, 14.7 for stoic, 12 for WOT normally aspirated, 10 to 11 for WOT in a turbo car, 9 for "pig rich" at WOT in a turbo car, etc. Those are the kind of numbers people have in mind as normal.A minor change I think I would make for higher accuracy would be changing your displayed stoich to 14.1. Our fuel in the northeast is e10, so stoich should be 14.1 vs normal 14.7.
We wouldn't have this problem if everybody had switched over to using Lambda 50 or 60 years ago instead of AFR.
Because the way a wideband works, Lambda versus voltage output to the ecu is the same no matter what your fuel is. The AEM "book" value for the 30-4110 is 2.32 volts is Lambda = 1. For all fuels, methanol, ethanol, gasoline, e85, whatever, even propane for god sake. Any of those fuels should give you 2.32 volts out of a 30-4110 when you are at stoic.
But hardly anybody (in the US) displays Lambda because they aren't used to seeing it. They don't know what it should be at different conditions. What they are used to is gasoline AFR.
So what most of us choose to do is display Gasoline AFR.
I never thought about this much until switching to flex fuel. My car could have any % of ethanol in the tank. My actual stoic ratio changes every time I put fuel in the car. But my tables all have 14.7 for the stoic ratio.
I think one place where using the 14.1 should be better is in the calculator on the fuel tab where you are supposed to be able to figure out what your Global Fuel should be from your injector size, base fuel pressure, and the stoic ratio of your fuel. It seems like it's very common for people to end up needing a little more Global Fuel than what they get from that calculator. That's probably one reason why (if they put 14.7 in there).
