angled t3 adaptor with holsets?
bsbllfit7
1,104
3
Feb 17, 2009
Salem, Oregon
hey there i found a mitsu to t3 adaptor flange that im wondering if it will work with an hx35. It would allow it to use the stock manifolds and it angles it slightly towards the radiator. This will help with water pipe fitment. here is a picture, post if you have experience with this or know anything about it
The piece looks nice, but my question is would it make the turbo to low like will the outlet on the turbo compressor hit the frame cross bar?:hmm: How much was this I would be willing to try it if it was cheap enough.
there are a few different models on ebay but they are all around 35 bucks shipped. That one in general was 38 dollars shipped. There are different angles on all of them. Some even have no angles
I built something sort or similar and uglier to fit my VGT turbo on a stock manifold.
It had to move out and down to fit, as well as the non standard flange as well as provide a waste gate port.
Its ugly but just to show the basic concept would probably work if you found the right one.
If you are trying to use a stock manifold with a HX-35 turbine housing there is no provision for a wastegate. The stock Holset internal wastegate is to small for a gas motor.
I've seen a similar adapter used on a VW, but it was cast and had a spot on the side for an external 38 mm wastegate.
well you can always have the stock manifold modded to fit a external wastegate. Or like the guy who posted on this with his own setup, weld the wastegate adaptor onto this housing adaptor
