Am I ready to drive for an alignment?
GSLENK
1,416
55
May 25, 2011
DC, Maryland
I did a check on my current alignment before I go driving 40 MILES to the shop I have chosen.
A curb made me overhaul a bunch of suspension stuff... I need an alignment.
here's how I took measurements. I made these adjustments through short test drives and eyeballing, this is how I will check/ perfect it.
Camber all around is less than 1.5* (most extreme is around there, the rest are around .5*.
Front toe is is about .5*
Rear toe in is about .25*
The front and rear tires are out of sync by about 10* on the left, and 8* on the right.
Heres my method from start to finish, some of my calculation methods are included. (I knew trig would be useful)
drive it and get it alighned, if you continue driving like that the toe is going to eat the tires fast.
I have some crappy rims/tires I'm gonna throw on to get there. Im worried about the 8 to 10 degree difference from front to back. Idk if it will be safe for 40 miles. i guess that means driving with a crooked steering wheel turned a little bit to go straight.
Well their alignment was flawless. I had a bent rear hub/spindle and somehow didn't realize it until after :banghead:
They offered a discount for an immediate redo once I swap hubs out. I will def take them up on it, I am sure the rear hub had something to do with limiting the amount of toe they could do (couldnt get 0, but got damn close) and it was perfect I forget the befor numbers, but after was
Front (both sides)
Camber= .025 neg
Toe 0.00
caster, cant remember...
Rear (both sides)
Camber 0.00
Toe in = .05
