alternator wiring harness connectors
3kgt2nv
2,023
19
Jan 7, 2011
poughkeepsie, New York
I just switched form a 90 engine control and engine bay wiring harness and have a question about the alternator. on a 91-94 gsx does the harness have a plug that connects to the brown connector on the actual alternator? or does it just use the wire that comes off the post?
thats weird as i took the engine bay harness out and there was no plug that went into the brown connector or one even near the right sport for the alternator to plug into.
do you know where there is an actual picture of the plug and where it ties into the harness.
I have searched but all i can find are threads without pics
Do you not have the '90 harness to compare to? It'll look the same. This is the best I find after a quick search and my engine is a little too warm to snap a picture: http://www.dsmtuners.com/forums/newbie-forum/296055-alternator-wiring-problem.html.
EDIT: Note on this plug, the release tab is missing as it broke off some time ago.
There's a yellow wire (which probably doesn't look yellow anymore) that runs to the engine fuse box, fuse 4, and a black and white wire that turns into the white wire that runs to the alternator/generator relay. It emerges from the harness at the same location the other alternator wire, the oil filter housing wires, and power steering pressure switch connector come from. But if it isn't there, you may need to start tracking it down in the rest of the harness.
