alternator problems
my car runs fine till I plug the alt in then it dies, and will not crank back unless I unplug it . also pos post getting hot
are you blowing the fusible link for the alternator? It could possibly be shorting somewhere, or the regulator fried.
It is oem correct?
all fuses good how do i check the regulator??? yes oem
think the guy befor me may have spilled powersteering fluid on it. tore it apart and cleaned it same results. maybe shot but it still charges so not sure
What makes you think its the alternator. Have you checked the voltage of the charging circuit? have you eliminated other variables? Many things can cause a misfire
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
