spyderdrifter
- 5,426
- 860
- Jul 11, 2009
Somewhere in,
Colorado
So here's yet another pointless alt belt tension issue that I'm sure can be found somewhere on here, Google, or some other forum. I did a search, but couldn't quite find what I was looking for. My alternator is squealing upon start up first off. So with that, I figured it's probably too tight and wearing on the alt pulley bearings, water pump pulley bearings, or the harmonic balancer. From what it sounds like after the squeal subsides, is that the water pump pulley has a slight random squeak. I've cheaked the tension on the alt belt, as you can see in the pic, and it's obviously looser than it should be. It's probably sitting around 1/2"-3/4". I know 1/4" deflection is about the norm. Can a loose belt cause this irritating squeal and the squeak in the water pump pulley? The water pump itself is only a month and a half old, and has only received maybe 40 miles worth of drive time at most. I've always been hesitant on tightening the alt belt too much because I have destroyed a harmonic balancer by over-tightening. I don't have a deflection tool either (yet). Any help would be awesome.
