2G All in one clutch?
420a non-turbo
Jun 13, 2017
Columbus, Ohio
My 1997 Mitsubishi eclipse 2.0 non turbo with a five speed manual transmission had a bad clutch. I replaced the clutch and the same problems occurred shortly after driving.. do I need to align an all-in-one clutch that's pretty assembled? If so how do you do that?
What problems are you having with the clutch. If you replaced the clutch with a modular unit, the flywheel aligns the unit to the crank. You can not use an alignment tool on these.
Your talking about the 4 bolts that connect the clutch assembly to the flex-plate? do you have then all torqued down and are you using the correct bolts?
Could your flexplate have been cracked/broken and you didnt notice it?
Its hard to say without seeing it.
I have done a fuuck load of 2gnt clutches and the only time i have ever seen a bolt hit any thing is when you turn the flexplate and one of the 4 bolts isnt turned in far enough.
It is possible ... I bought identical bolts so I don't think that's the problem they may not have been torqued enough its just really hard to torque from under the car with very little space
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
  • For sale 1g 1G AWD Engine Side Splash Shield
    1G AWD Engine Side Splash Shields $55 a piece + shipping & paypal fees* I don’t have any...
  • For sale 2g 2G OEM Cargo Net
    2G OEM Cargo Net $40 + shipping & paypal feesYou must be registered to see element.
