Alky/Water pump mounting location?
TTA89
100
Feb 1, 2003
Montgomery, Alabama
Where do the 1g guys have their bottle & pump mounted? Sparking ideas around.
i use the windsheild washer bottle.. I drilled a hole and put a barbed fitting on the bottom. I then had my pump right infront of it. I have since moved the pump and ran a line to the stock SMIC location.
I also tapped into the washer fluid bottle, then ran the line to the pump next to my K&N filter. The space just over the old stock side mount location can just fit the pump. I had thought about mounting the pump where the old sidemount was but I was afraid of water splashing on the pump from rain and puddles.
I went overkill and mounted a 4 gal cell in the trunk with my sureflo pump there as well. Not good for carrying stuff, but I dont like to run out of meth, and there is a future plan that will require additional meth as well so....
FWIW water wont hurt the pump.. they see worse abuse when used in RV's
    • Detail
    • dsmmario
    • Canadian_CD9A
    • my98gsx
