Alky Setup Thread and PSI Improvement
Car Cannibal
688
166
Jun 7, 2003
Chicago, Illinois
I figured this might help others get an idea of what an alky kit will do on their DSM if we have a thread with setups in it.
Kit = Devils Own DVC-30
Nozzles = 3GPH Pre & 12GPH Post
Alky = 100% Meth
Turn On = 10psi
Max = 19psi
Pump Gas Psi = 19
Alky Psi = 27
AFR in 3rd = 11.2
Turbo = PTE 61/52S in T4 .68
Intercooler = FMIC
Dam that is some pretty good improvements anyone else see similar?
BTW, that's with 24 degrees of timing at WOT from about 4k on. I've hit 28psi on cold nights in 3rd without any knock, damn this stuff is great. :hellyeah:
Glade you are happy with it. Its a great mod and thats why so many e85 have been switching over to it.
Kit = Snow Performance Stage 2
Nozzles = 625 + 375 ml/min dual nozzles
Alky = 75/25 meth/water
Turn On = 12psi
Max = 20psi
Pump Gas Psi = 28
Pump Gas Timing = 15*
Alky Psi = 38
Alky Timing = 18*
AFR in 3rd = 11.7
Turbo = Holset HX-40 (56mm)
Intercooler = FMIC
At 38psi and 18* timing I see zero knock. Im scared to push coolant and/or blow the HG so I leave it there. Serves me well though, 565 awhp and 524 lb/ft of torque.
Turn On = 12psi
Max = 20psi
Pump Gas Psi = 28
Alky Psi = 38
Alky Timing = 18*
AFR in 3rd = 11.7
Intercooler = FMIC
This is exactly what i wanted to see. I was trying to figure out if alky/meth would be enough to get my HX35 to run close to 35-40 psi with meth and pump.
Kit = BECOOL Stage 1
Nozzles = 7 GPH/M7 (441ml/min) & 1GPH/M1 (63ml/min) Pre Turbo nozzle
Alky = 35/65 meth/water Washer fluid (Blue Juice)
Turn On = 7psi
Max = 17-18psi
Pump Gas Psi = 17-18
Pump Gas Timing = 18*
Alky Psi = 27-28 with some blips of knock that could be false knock.
Alky Timing = 16*
AFR in 3rd = 11.5
Turbo = MHI E316G
Intercooler = Supra Side Mount
Not been tuning it long. Hoping to max out the turbo when done.
