SiX22oH6
- 33
- 0
- Oct 12, 2010
southern NH,
New Hampshire
Im running Ecmlink v3 with a AEM wideband, im getting 12.3 on the wb and i read it should be around 14.6? how do i adjust it using the v3 thank you in advance
This is something I don't understand. You payed $500+ for a tool that you have no clue how to use (unless it came with the car). You need to start with the basics. Read, read, read the ECMTuning wiki.. Get on their forum and learn to basics of manipulating parameters in the ECU.
start [ECMTuning - wiki]
While true, not everyone learns that way. I bought it without knowing how to use it. It's not that difficult to learn and for some people, like myself, HANDS ON is the best way to learn. I just made sure, that before I made a change to a parameter, I knew exactly what that change would do.
You can read about how to weld, or draw, or play basketball, but with out hands on practice, all that reading is useless.
OP, what is reading 12.3? The wideband gauge? or the logged value in DSMLink? or both?
... Before people jump the gun on purchasing link, they should have the software downloaded and viewing other user's logs on their own pc (which I think is great). There are tons of threads where Snoboarder (for instance) changes a few parameters and has the OP post back with results. It's not hard to follow along. I've never dabbled on the dsmlink forums, but I'm sure the support through wiki's and how-to's is pretty extensive.It's just sad... Before people jump the gun on purchasing link, they should have the software downloaded and viewing other user's logs on their own pc (which I think is great). There are tons of threads where Snoboarder (for instance) changes a few parameters and has the OP post back with results. It's not hard to follow along. I've never dabbled on the dsmlink forums, but I'm sure the support through wiki's and how-to's is pretty extensive.
To the OP: If you seriously watched all of the videos, read all of the material in the wiki, used the search function on dsmtuners and the link forums, talked to Tom, and STILL are wondering what to change to dial in idle AFR's... then maybe link isn't for you. ....[end rant] so if you want to get somwhere, post a log. It's hard to tell what your problems are through broken english.
Relax dude, let him learn the way he wants. It is his money/car after all.
Everyone is new to everything at some point, so please, give the guy a break.
Now post that log OP.
