Aftermarket Control Arms (AcDelco, Moog, Raybestos, Deeza, Dorman, Mevotech, Beck/Arn
What aftermarket brand do you use?
  • Mevotech
    Votes: 1 4.5%
  • Acdelco
    Votes: 1 4.5%
  • Beck Arnley
    Votes: 4 18.2%
  • Dorman
    Votes: 3 13.6%
  • Moog
    Votes: 12 54.5%
  • Replacement
    Votes: 0 0.0%
  • OES Genuine
    Votes: 0 0.0%
  • Deeza
    Votes: 0 0.0%
  • Raysbestos
    Votes: 1 4.5%
  • Total voters
    22
chinola69
642
30
Sep 22, 2007
Yonkers, New York
I am about to change all of my frt control arms. I am not going with Misubishi OEM parts, So my question is what brand has the best quality parts (don't take money into consideration)? AcDelco, Moog, Raybestos, Deeza, Dorman, Mevotech, Beck/Arnley, OES Genuine, Replacement?
This is all for a 2g GSX
Good guess on which aftermarket supplier has quality parts. In general, to properly design and test parts you will easily out-spend any profits. Why? testing is expensive and aftermarket volumes are low (amortize testing & tooling over low volume).
The 2g has forged lower control arms (double ball joint design). The lateral arm has spring/jbump loads going into a tension-oriented outer ball-joint. This is a critical joint, and as most are aware, it was fixed with a recall. Has anyone ever heard of an aftermarket parts supplier having a recall? Most have a disclaimer for no guarantee. Look at the fine print.
With OEM parts, at least you know they have passed some sort of durability, on manufacturing-process-produced parts.
Fabricating a part that works is one thing. Manufacturing it for many-parts is different. Generally speaking the top "Nascar" or "A-team" fabricators are not making production parts.
I realize this is not the answer you are looking for; but that outer-ball joint wants to rip out of the arm (tension joint) everytime you hit a bump. If there is a design that has been proven on (hundreds of) thousands of cars, for hundreds of thousands of miles (OEM) it might be a good alternative.
In my opinion, the only reason to change the 2g lateral lower arm would be to incorporate a compression-outer ball joint (requires new design of knuckle and lca).
I've heard Moog is decent quality...
Which arms are you referring to? The front lower lateral arms are only about $40 each for OEM, the curved arms are going to run a couple hundred.
Out of the parts, I've been told that Moog is they way to go.
